Can anyone identify this engine model?
21 Jun 2009
I know it's a VP but what model is it? Is it possible to tell from the pictures?
The boat is a 1980s Fairline Sedan 32.
I believe the sterndrives are 270 legs.
Divemaster1
15 Jan 2002
Aberdeenshire, Scotland
Could be an early AQAD40 A ... in that case 130 Hp ... the B came out a couple of years later with 165 HP.. Guess the 270 leg will add to the clues as the B came out around the same time that Volvo released their first Duo-prop drive .. (290 ??) ..
superheat6k
10 Jan 2012
South Coast
I would suggest it is an A as it looks identical to the TMD40A on my last boat. If you want the workshop manual and spares lists please PM me. Not sure what the physical differences were from the A to B to C.
21 Jun 2009
Thanks guys.
can I ask what the difference in the AQAD40 A and the TMD40A is?
Are the both the same engine?
sap_2000
15 Jun 2005
Oslo, Norway
It looks to me a AQD40 as no aftercooler is seen, and i'm guessing it is a "A" model because of the 270 drives and the black volvo penta sticker. With aftercooler it is named AQAD40
superheat6k
10 Jan 2012
South Coast
Agree not an AQ'A'D - no aftercooler on this engine, the plastic air filter casing attaches directly to the turbo, which blows directly into the long inlet manifold with the nibs feeding to each cylinder along the top of the engine parallel with the rocker cover.
I also have a list of cross over parts for filters etc if required.
Be aware that the heat exchanger is a plate type, unique to VP, so an expensive and possibly obsolete item now if this fails.
