johnnyboy
New Member
Re: New Transom Pictures showing full width cut out !! !!
Okey dokey guys, progress report with questions!:-
I have bought all the stuff I believe from your input I will need to put this baby back together. I got the stuff from west systems. I have also cut a piece of 3/4 inch ply the whole width of the transom, made a template and cut it to size. I have left approximately 10mm around the edges all the way around. I have drilled holes at 2" centres and am ready to rock. My first question is a simple one. I want to know the best way to bevel the edges (according to oldsaltoz a minimum of 5" all the way round the sides and the underside) Should I use an orbital sander/discsander(and if one of these do I use 60 or 80 grit) or grinder (and if a grinder what size and type of disc) Also, I have some microfibres for the structural filling which I intend to use around the transom but will this be too hard to sand where the hull sides turn round the transom??? I also have some LOW DENSITY FILLER FOR THE FAIRING (407 I believe) Shouuld I use part microfibres and part low density filler to make the shaping easier or is this a no-no??? And how about rounding the edges of the fibreglass to make laying the cloth easier? Do I use the same tool for this??? Also, I have bi-axial cloth and roving woven. I will not be able to use one piece to come round from the sides, across the transom, back round the other side and under the underside of the hull due to the shape. How do I best get round this or is it not important??? (i.e does it matter if each layer is made up of several cuts butted together, with each next layer laid like brickwork (i.e with the joints staggered so you never get one joint the full depth of the laminate) or do I have to laminate each layer as one piece and somehow cut a slit wherever the angle dictates it??? How about the width of the transom, since I have already cut the back off of the boat would it offer any benefits if I made the transom ply thicker and used more layers of laminate??? And one more thing (forgive me, I know I ask a lot of questions, lol!) I bought the west systems how to dvd which I have watched several times, and one thing I noticed was the suggestion that during a repair, the largest piece of laminate should always be put in first. Does this apply in the case of my repair, or is that only when doing patches??? I have already stated that I feel it would be difficult to re-instate each layer in one piece, hence the question!
