QBhoy
Jeez. Some utter wild goose chase suggestions here. Is it the same when you take the plugs out ?
Tbh i didn't even think of trying that.Jeez. Some utter wild goose chase suggestions here. Is it the same when you take the plugs out ?
Yeah its fully working and mounted on transom.Is it still doing it now that the engine is running properly?
Asking because it didn't do it after the longer run, and it could be that the irregular running is stopping the backdrive of the Bendix which ought to cause it to disengage.
In other words, there might be nothing wrong with it.
Well if you can start it with a rope leave the motor off and run without , if no noise its the motor.Yeah its fully working and mounted on transom.
When i start the motor on my driveway it does it every time.
The best way i can describe it is like the motor in the starter is being forced to spin faster than it wants to by the flywheel and with the speed of the flywheel it struggles to disengage causing the overspeed whine and crunching noise.
Today ive removed it, stripped it down, cleaned it fully (BTW those bloody brushes where a nightmare!)
And rebuilt.
Tomorrow is crunch time if...I've fixed it or broken it fully.
Put a teeny tiny smear of grease on the bearing of the bendix shaft (not the bendix itself and a smear on the pinion teeth to see if that will help it disengage a bit better.
Tbh i have no confidence and if it still makes the noise i think i will have to bite the bullet and buy a new one as i really dont want this to give in at sea.
I will keep you all updated in the morning folks![]()
Yeah il give that ago good thinkingWell if you can start it with a rope leave the motor off and run without , if no noise its the motor.
Over the moon mate £140 savingNice one - and at least you have pin pointed the problem.
Well done.Over the moon mate £140 saving![]()
