rafiki_
Gasoline is for girls!
Pass the lippy dahhhhling. Mind you, I just luuurrve the sound of the Jag 5.0 V8 under throttle. If that is girly, well then, I will have to live with that
Lynall,
About ten years ago I was asked to take serious look at Landrover 300 Tdi for installation in Bowler Wildcat.
Putting the 300Tdi across the dyno told a story.
#1 The standard VE pump was hopeless. Land Rover VE has a non linear output, juce up the pump, max power increases but bottom end collapses, no good for off-roading.
#2 Tubomachinery did not cut it.
I found VE used on 4 liter off 71/2 tonne truck motor with a linear output, using fuel pin from MAN truck and also well known that TD5 Garrett is great widget with correct manifold.
End result was solid 200 hp at the top with no compromise bottom end, rocket ship motor, did 3 for French race team.
Latestarter
Thats excellent info thank you.
Can you remember what truck the inj pump was fitted to? must have been a while ago as most stuff has been c/rail last 10 years or so.
