Latestarter1
Overpropping: This was half resolved. I fitted a smaller prop, I can't remember now the exact size but it was smaller in both diameter and had less pitch. It increased rpm by 500, but made no difference to boost pressure or top speed obtained.
I've since found the original spec sheet supplied by Lancing when the repower was carried out, they supplied a 16X21 long hub which is the prop currently fitted.
I can't post pictures, the turbo has been rebuilt and I didn't get any shots before it went. The compressor vanes had small chips around the edges.
The exhaust side looked Ok before rebuild, the vanes looked to be in good condition, and there was very little discernible play in the bearing from that side.
I don't know how much oil it was passing, there was a small pool of oil settled in the inlet housing when the turbo was layed on it's side after removal. It was never vast amounts, it didn't smoke excessively when running.
Play was quite considerable though, difficult to quantify but it was probably rocking by 2mm or so?
The incorrect injectors were instantly spotted by my mechanic. Originally, it would have been fitted with the Yellow spot full flow 130ps injectors, but at some point they had been swapped back to 75ps injectors. The thinking was that if the injectors were incapable of supplying enough fuel, full boost or power was never going to be achievable.
It's certainly helped, previously I was reaching 2300rpm and 2.5psi boost at WOT, with the rebuilt turbo and full flow injectors it's now reaching 3100rpm and 7 psi. But, it's still not enough to get on plane, top speed has not altered at all, only the elevation!
Apologies, did not realise that turbocharger had been rebuilt. Only one bearing in turbocharger so play should be the same, however no matter clear evidence that turbo was passing oil.
Please do not be too hung up on boost at the moment, it is a characteristic of your propeller demand curve, do not assume data sheet prop dimensions are are correct, could be a case of garbage in garbage out.
Once you have CAC back on can you confirm high idle rpm.
On the subject of propeller dimensions, let's have some data and run some numbers, accurate displacement, drive reduction ratio.
