ovprescott
New Member
Thank you for any efforts to date, I no longer require access to the software, My issue has been resolvedHello I would appreciate receiving a copy of the update for my AI50. ovprescott@gmail.com
Hi RobThe latest version of the software for this unit is v 1.9.4. If you have an earlier version and fancy a software upgrade then give me a shout - I have the upgrade files and the methodology.
H
Hi Tim,
I've sent the files. Edit your original post and delete your email address.
Rgds,
Rob
Files were sent last Sunday, did you not receive?If anyone has the copy of the relevant files and instructions I would really appreciate it if you could send them to me too please.
Trying to feed the N2K output via a Wi-Fi gateway to Navionics and OpenCPN but getting very sporadic results. Date issue may be at fault.
VladdyFiles were sent last Sunday, did you not receive?
Looking back, I found it in my Bin. Thank you so much.Files were sent last Sunday, did you not receive?
Navig8tr, thanks for that tip. I have received the upgrade files and will give that a go. Failing which my YDNR-02 gateway also accepts N0183 input so there is that option.Vladdy
I suspect there may be a problem with the Simrad AI50 N2K output format. I have had sporadic problems trying to feed AIS to a Raymarine MFD and presently decoding the diagnostic data.
If you need to get AIS data to a Navionics set I have used the NMEA 0183 interface to feed a Quark Wifi converter with excellent results.
Hi, my email is tamaherewoollacott@gmail.comThe latest version of the software for this unit is v 1.9.4. If you have an earlier version and fancy a software upgrade then give me a shout - I have the upgrade files and the methodology.
Hi,Goodmorning from the Netherlands. I am halping out a friend who bought a German boat with an AI50 inside. Old firmware and I also need to chnage the MMSI to the new license. I was told this is done using a reset file. Browsing through the internbet this post was tyhe best match.
Any chance you can help ? Pedro from S/V Blauwvoet
pedro.wyns@gmail.com
Replied.Hi, my email is tamaherewoollacott@gmail.com
Hey, Do you still have this file please. ThanksThe latest version of the software for this unit is v 1.9.4. If you have an earlier version and fancy a software upgrade then give me a shout - I have the upgrade files and the methodology.
Yes but I’ll need your email address to send it to you.Hey, Do you still have this file please. Thanks
alexsearider@gmail.com Thank you so muchYes but I’ll need your email address to send it to you.
