Ian_Rob
To check my ST60+ can I just compare the indicated SOG withone of the GPS apps that are available , whilst motoring at slack tide, to get an accurate calibration?
Send reply #2ST60s etc have a "match GPS speed" function in the user menus. Motor at about 4 or 5 knots on steady throttle for 150-200 metres in a minimal tide area or time, turn and repeat on the reciprocal course, then if the GPS speeds each way are within 0.1 or 0.2 kt of each other do a third run and set your log to match the GPS. It will be about as good as you will get for log accuracy. As others have said logs are rarely accurate throughout the speed range, hence do it at mid-speed.
The trouble with measured mile markers is that there may not be one close, also they often tend to be in open water and sea conditions can affect your steady speed. You can usually find a smaller area with minimal tidal flow or pick a time of slack water for the quick 'match-GPS' way.
The constant engine speed is to see if your two-way run differs on GPS. If so either wind/current/tide is affecting the SOG vs STW.Send reply #2
Constant speed is not critical.
