Cable Glands
beneteau_305_553
1 Apr 2002
Norfolk UK
Does anyone know of a proper cable gland that is watertight to IP67 and suitable for mounting through the cabin roof in front of the mast?
The standard industial glands seem to be made for either M20 or M25 threaded sockets or have a backnut that is only suitable for a base thickness of up to 2 mm.
I've got chrome plated brass ones at present screwed onto the cabin roof but the rubber gromet doesn't seem to be compressed sufficiently by the knurled nut to maintain a watertight seal under arduous conditions.
<hr width=100% size=1>Richard
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
I do not know if it would be suitable for you, but why not trying a small gooseneck, 10-15cm high, you thread the wire and then fill it with silicone, easily removable. Works very well.
graham
I have something similar the only way I have got them 100% watertight is with a smear of "seakaflex"ontop of the grommet around the cables.
Not very pretty and has to be redone if you pull the cable out for any reason.
pvb
UK East Coast
As an alternative...
Instead of conventional cable glands, had you considered using a stainless steel gooseneck pipe? These are used by Hallberg Rassy and are very effective. You can buy them from HR Parts & Accessories for about £30 plus shipping.
<A target="_blank" HREF=http://www.hr-parts.com/Shop/enter.html>
</A>
Strathglass
Fife
Re: As an alternative...
Do you have contact information for HR? .
Just what I have been looking for.
Iain
Novice
22 Sep 2003
Hanse use these as well, and may be able to supply the part cheaper.
pvb
UK East Coast
No silicone sealant...
They're not watertight, but you'd need a lot of water over the deck before it would leak. Some people stuff a bit of rag up the open end. You could seal it with silicone, but that might make it difficult to remove/replace wires at a later date.
Gunfleet
1 Jan 2002
Orwell
Re: No silicone sealant...
I'd have though some neoprene or even a carbouy rubber plug would do the job nicely.
