stevd
Hello all,
I have ran into some difficulty with my Bukh. When the engine is cold it runs fine and starts without any issues. Once it has warmed up it is a different story.
After around 30 minutes of running from cold, the engine will some times stall when it returns to idle from running at high revs. If it doesn't stall it runs at a lower than normal rpm and refuses to increase speed when the throttle is opened. If the engine hasn't been running too long, say 10 minutes or so, sometimes the rpm will increase but it does take a lot longer to do so. It is as if when this happens it isn't getting the fuel it requires.
So far I have done the following;
Fuel filter is clean, although I haven't checked on the gauze on the lift pump yet but I will do next time.
Fuel pick up pipe is clear
There is no vacuum being created in the tank, breathers are clear and to be sure I have ran with the filler cap removed.
There is no air in the diesel system.
My first thoughts are with the cooling system, I haven't removed the water inlet pipe to the block yet as I didn't have the correct allen key for it, but I did run a flexible sink cleaner wire through the pipe and there didn't seem to be any restrictions there.
I removed the thermostat completely, although it does seem to be functioning correctly. I did pour in some water into the thermostat housing and it didn't clear as quickly as I would have expected it to. So I am now going t buy some rydlyme to see if that clears up any blockages.
could an overheating engine cause these issues, or should I start looking at the fuel rack and governor on the injector pump ( which was rebuilt 18 months ago anyway).
I have even changed the oil (clutching at straws)
Why would the engine behave like this when it is warmed up?
Any ideas?
Many thanks
Any ideas?
Many thanks
