rotrax
del
Not "standard" but on some boats of that generation, the panels have been cut out of the inner matrix leaving the ribs, which are then laminated directly to the hull. Which requires furniture removal and basically raises the construction technique to what it "should" have been all along.The separation of the internal grid is exactly why I would never buy a modern yacht, nor one with a sandwich hull (search Google for Hazar 30 yacht) . I have balsa cored decks and they are bad enough.
As far as I know there is no standard way to refix the internal grid, so may be they live in the land of hope, rather than the land of hopelessness they will end up in.
On a modern boat with a raised and sloping cabin top you are best having your reefing lines led aft to the cockpit. Going on deck on such a boat can be dangerous. On a clear flat deck going to the mast to reef is not a problem. You can reef faster at the mast. Super simple systems with no friction compared to the turning blocks needed to get lines back to the cockpit. As a bonus you dont have a cockpit full of lines.why would I want to leave the safety and comfort of the cockpit to put a reef in when I can do the same job from the cockpit with the lines led aft?
That is not the quick fix anyone would dream of, that is major surgery. The boat would definitely be stronger, but as it had been "repaired", most future buyers would probably not touch it with a barge pole - even though you and I know it is now structurally better than when originally built. This would probably depress the secondhandvalue considerably. The owners should be trying to get it classified as unrepairable and get an agreed amount from their insurers. They would be better off financially.Not "standard" but on some boats of that generation, the panels have been cut out of the inner matrix leaving the ribs, which are then laminated directly to the hull. Which requires furniture removal and basically raises the construction technique to what it "should" have been all along.
On older boats you get water ingress through cracked encapsulated keels that doesn't get noticed, let alone fixed, you get rotting stringers, delaminated rudders, osmosis, rotten balsa cored decks, rotting ply bulkheads, corroded chain plates, corroded electrical wiring ... the list is endless. Nothing lasts forever, not even MABs, at least not without a considerable amount of work to stop leaks and keep them in good condition.
Anyone buying a boat needs to keep that in the back of their mind, the older the boat, the more likely there is to be a very nasty surprise hiding in there somewhere - an AWB under 10 years old wont have a lot of these long-term deterioration problems - more likely to have repaired accident damage which on a young AWB is pretty easy to spot.
I want to sail, not spend thousands of pounds and hundreds of hours on repairing nasty surprises. You can get into every corner of a modern AWB - the tanks are moulded plastic, the keel, and bolts, are visible - the rudder can be dropped and bushings/bearings replaced in a day - you can trace and see all the pipework, wiring etc. Every system has excellent access. In my AWB I can see the entire inside of the hull just by lifting removable floors or opening lockers- the only section of the hull I can't access is under the wet cell used for the heads ... I can see under it, just not access it.
Just these 2 sailing blogs would put me off an old boat for life .....
Sail Life
HaveWindWillTravel.com
.... in fact, YouTube is full of dreamers buying older "blue water" boats just to spend most of their lives fixing them.
PS: A sailing friend of mine had the grid in his SunFast re-attached after a grounding ... that was a decade ago and the repair has never needed to be revisited.
I got the impression that the thread has been pretty positive towards modern manufacturing and as the owner of a quality old boat I agree. I also prefer spade rudders despite having a transom hung one. Of course there are exceptions to the rules and other priorities when purchasing a yacht. Budget and Aesthetics play a large part of any purchase. lucky mine was cheap and is the best looking boat you will see.Reading the last few boats, I think there is a tendency to confuse quality with age - or in other words a boat needs to be old than well built.
I believe this is wrong.
Although they may be fewer there are still builders around that produce modern designs with exceptional quality - of course at a price.
Island Packet may not be the best example, because I accept the long keel isnt everyones cup of tea, but the build techniques are up to date, and the quality is excceptional. For example, there is nothing "old" about a hull that isnt balsa or foam cored, rather it is a more expensive construction technique that will result in the long term ins a stiffer and more resileint build. Yes, it will add a little to the wieght, but with a modern design not to an extent that will effect performance.
Better examples maybe HB, Nautor, Discovery and of course Oyster. They all make yachts that will go around the world and not show they have. Beneteau will equally make a yacht that will go round the world but it will show it has. For me, that is the difference.
Have you tried changing your toilet hoses in a modern yacht? In many modern boats they are behind dropped in furnture blocks with no access. I can remember my father having to change an engine pipe and found it was behind a bonded in section of furniture. It had to be broken out to gain access and a new section made allowing for future access and veneered to match the rest of the cabin. Oh, the joy of a modern yacht he said. To me a large cockpit and open space cabin are both dangerous in rough weather as you do not have sufficient hand holds or places to brace against plus there is further to fall across.On older boats you get water ingress through cracked encapsulated keels that doesn't get noticed, let alone fixed, you get rotting stringers, delaminated rudders, osmosis, rotten balsa cored decks, rotting ply bulkheads, corroded chain plates, corroded electrical wiring ... the list is endless. Nothing lasts forever, not even MABs, at least not without a considerable amount of work to stop leaks and keep them in good condition.
Sail Life
But Island Packet never sold a lot of boats - maybe 2000 or so in total? And the market wasn't there for what they wanted to produce, which is why they went bust.
Most owners of decent-sized Swan/Discovery/Oyster yachts will have paid crew to keep the yacht in sparkly order. Most owners of Beneteau yachts will be DIY maintenance.
By comparison in my 40 year old Westerly Fulmar all my bulkheads are bonded to the hull and deck, the deck joint is not just bolted, but glassfibred over. All the original deck fittings are covered under the deck with glassfibre to stop all leaks - but a pain when some work does need doing. They used real wood and veneered marine plywood, and provided the boat has been maintained, there should never be any problem with rot. All my plywood floorboards can be lifted and I can see all of my keel bolts. The keel is on a low stum which places the weight even lower and creates a small bilge compared to a very flat dish of the hull. I have a propellor shaft on a P bracket and only requires either a greased seal or a water lubricated one, neith cost much to replace if needed. By comparison the sail drive has been made for manufacturers benefit. They just drop it in the hole in the hull and the job is done - quick and cheap. Except every 7 years or so iy has to be lifted to replace the seal, not a simple DIY job and most but owners pay a yard to do this. I can drop my rudder just as easily as a modern boat. I have no osmosis or problems with the rudder. There have been additions to the electrical system and all the original wiring is still all working. There is not rot in my balsa core deck, the only problem was the anchor winch had caused the reinforcing plywood pad to delaminate but was easily fixed with epoxy injected in and is now solid again. One day I ran aground on a sandy bottom doing 7½ knots and no damage done when I hauled her out 6 months later. Running aground in a modern yacht is something you do not want to do and requires immediate lifting to check for structural damage.
So when I do a comparison in construction methods all I can see is cost economies from factory building. Not all of them are for the long term benefit of future owners. At the weekend I was chatting with another boat owner. He had recently been talking with a maintenance guy working in a marina and was being kept very busy with all the repairs necessary due to modern manufacturing techniques. His story of an owner requiring an Ebersparcher to be fitted is just typical. The exhaust was to be fitted on the transom, but there was a very decorative design across the transom and the owner requested the exhaust must not touch the graphics so he must be careful. The fitter almost laughed as he could easily drill from inside because the transom was so thin, the pattern showed through the glassfibre.
For me I want a yacht that sails well and traditionally built with bonded bulkheads. I understand why so many people are attracted by yachts with so many domestic facilities and sun lounging areas as that is their priority in a mass produced yacht produced in a factory at a keen price. Unfortunately there are no modern yachts I am attracted to.
I think Fulmars are one of the great boats of our times. They handle heavy weather well and were used by the local sailing school for many years. They were out in all weather.Baggywrinkle, it is funny how we keep talking about AWBs and MABs, but never talk about classic yachts. I am talking about the classic yachts from the 1920's onward, normally made in wood. These are more up the scale of dedication than my restoration. Why do people spend so much money on such out dated designs, but they have a dedicated following.
I never expect to get my money back from my restoration, let alone any recompense for the hours I have put in. I have done it all for my own satisfaction and pride of ownership. I could have bought a new 32ft yacht, but I just dislike the modern designs and construction methods, so I decided to buy a yacht that met my requirements and spend what I needed to bring it to a high standard as close to new condition. Before I bought Concerto I had never sailed on any Westerly and thought them as floating caravans, but now many think I am biased towards Westerly yachts, but they are well built and are still fit for purpose as per the original design. Centaurs were launched over 50 years ago and are still recommended for beginners on a budget. I have no immediate intention to sell Concerto and will keep her for probably another 10 years with little maintenance, probably similer to a new yacht.
It was lovely sailing yesterday and small things like making all 4 mainsail leech tell tales flying aft made it a memorable day. Doing this on a MAB and keeping up with a 36ft AWB over about 20 miles gives me a smile. Concerto is a sailing yacht and not slowed down by all the modern requirements of buyers of modern yachts. Virtually all of the AWBs have been greatly influenced by the demands of the charter market in warmer climates. They are great as floating cottages being used by charterers where they motor almost everywhere to experience the boating life (ha, ha sunbathing is not sailing)., According to most marinas in the UK only 15% of boats go out regularly even when used frequently to stay on, so that means few AWBs are sailed regularly.
Overall I still expect I will loose less money than the decreciation I would have on a new yacht. The number of people who have said they would love to buy Concerto is long. Next year she should be at Southampton Boat Show as the boat on the Westerly Owners Association berth, so everyone can come and see her and chat. The following year I will be circumnavigating the UK singlehanded to include Orkneys and Shetland. A few years later I expect she will be moved to North Wales as we plan to move to Cheshire to be nearer our daughter and grandchild(ren). Fully exploring a new sailing area is going to be fun. I do know when it is time for me to swallow the anchor I will have had at least 15 years with Concerto and she will be very easy to sell due to her condition. She will still be sailing in another 25 years when she will be 65 years old, can you say that many AWBs will still be sailing at the same age? I very much doubt it and I expect many will say then that they weren't built like my Fulmar and did not last.
