wearesailing2
Compleate rip off, if you have no gas elec or bog £100 to lok at a fire ex is too much. No wonder people are not going on the thames
I spoke at length with BSS after the fire and suggested that a Bilge Blower should become part of the required standard .
The only issue with a Bilge Blower are the "Know-it alls" that tell you "Oi!, switch your engine off in Locks!" - I had this on virtually every trip out this year.![]()
A bilge blower is only supposed to be run for a couple of minutes before starting the engine and before refueling to clear the bilge, I've never heard of one being run continuously.
To make sure the engine and bilge
areas are properly ventilated:
• Use the "sniff test" to check the engine
and bilge areas for fuel vapors before
starting the engine.
• Always run the bilge blower for at least
four minutes before starting the engine.
• Continue to run the blower until your
boat has reached cruising speed.
• Always run the blower when running the
boat below cruising speed.
True but there's nowt wrong with leaving one on all the time. It ensures a cool flow of air over the engine and eliminates bilge odours as well as being a safety issue. Anyway Steve Poos direct into his bilge and the smell would be unbearable if he didn't![]()
