Quandary
My boat is five years old so as we berth in the Crinan Canal we have to have to have our boat inspected and certified this summer. Until now it has been covered by the builders CE certificate. I spent a wet afternoon today going through the regs. and it seems I need to deface my pristine external grp and internal wood work with a number of dopey labels and install a bubble tester in the gas locker.
The remaining questions refers to the fuel supply to the Eber. which like the supply to the engine emerges from the top of the tank but unlike it does not have a cut off tap. Two questions arise, first, the Eber. supply pipe is copper as I understand plastic diesel pipe is not acceptable to the regs. but elsewhere in the advice paragraphs it states that copper pipes are not suitable for use with diesel fuel, I presume it must affect the fuel in some way, can anyone explain?
The second question is how to achieve effective emergency fuel supply cut off as demanded; I have a dedicated switch for the Eber electrics which can be used to cut off the 12v. supply to stop the fuel pump (and the fan) and since the heater is much higher than the tank should effectively stop fuel supply, in the opinion of the panel is this a satisfactory method? I do not want to try to install a tap in such a fine copper fuel line even if I could find one small enough it would have to be installed like the tick tick pump by sleeving with rubber providing another potential point for leaks.
