Will_M
Hello all!!
Who has actual experience good or bad of the Brunton Auto Prop??
The reason I asked...
Having just fitted one, these are the results. Max achievable rpm has increased although within the correct operating parameters of the engine. Boat speed is the same as was with its 3 blade fixed propeller. At the high rpm range cavitation is now felt from the Auto Prop. Generally vibration has increased.
Everything is in very good order, ie shaft bearings, engine mounts etc etc.
