LittleSister
I've broken the positive terminal of a very expensive Red Flash AGM battery (tiny size, high CCA) I had yet to install (while 'borrowing' it to start another boat's engine). The terminal is M6, and I'm left with a short stub with a damaged thread.
Any suggestions how this could be repaired or worked around?
I am guessing that welding or similar could not be done without potential damage to the battery or the person doing it.
Is there any kind of conductive adhesive I could use to fix some type of supplementary terminal to the remains of the original?
I could perhaps secure some kind of bar across the top of that end of the battery using a strap under the battery, then that bar either bearing directly on a ring wire terminal on the battery's terminal base, or with a bolt through the bar to clamp the wire terminal against the remaining base, but would welcome suggestions of other potential solutions.
(First 2 photos show the undamaged negative terminal. The last photo shows an M6 nut just nipped on the top of the damaged terminal thread, which allows me to clip my battery charger to it for the moment, but doesn't give enough contact area or pressure for a proper secure connection for engine starting amperage.)
