Leighb
Yet for my rather modest 34 foot boat that is too low without having to do tidal calculations
What is your air draft then? 58 feet seems a lot?
is the mast keel stepped
If your 34 footer has an air draft exceeding 59 feet, she has an unusually high aspect ratio rig and can hardly be described as "rather modest".Yet for my rather modest 34 foot boat that is too low without having to do tidal calculations
I for one will be sorry if the new crossing means that sailing barges can no longer access the wet dock without housing their top masts - it doesn't seem a lot to ask that the new crossings should not reduce the available air draft to less than is currently available under the existing Orwell bridge. However arguments for that are only weakened by exaggeration of the potential difficulties.
While I believe that progress is inevitable, I also think that all reasonably practicable steps should be taken to minimise the problems created by that progress.
Peter.
Peter
Barges will no longer be able to reach St. Peter's Port if the bridge across the New Cut is built. In fact very little will get underneath it.
57' 5" plus (presumably) VHF, windex, etc.
I = 14.7
P = 14.3
mast 17.5
Bridge 18 HWS
How annoying -
We are 17.4m plus VHF antenna . . . . or so the paperwork says
I'm going to have to find a way of measuring it now
(and not impirically - by hitting the bridge)
Many in the Ipswich marinas will be taller.
I recall the owner's manual gives the air draft as 17.5m and it's not impossible that the mainsail luff lower measurement band is approaching three meters from the waterline.
Happy enough to go over the tidemill's cill with a couple of cm to spare but I'm more circumspect when it comes to the top of the mast and bridges or power lines!
This says a little less http://www.maxisidorna.com/maxi/data/en/27
I guess sending a tap measure attached to halyard up the mast might be cheaper than a try it and see approach.
From the article linked to in post #74
I guess sending a tape measure attached to halyard up the mast might be cheaper than a try it and see approach.
It may just be me but when going under the Orwell bridge the gap between the mast and the underside of the bridge looks a lot smaller than it really is
When heading to/or arriving from the Blackwater or the Crouch I would aim to be at Pye End around local LW.
When did you last see a sailing barge up the New Cut? The barge masters I know would sooner lock in to the Wet Dock than risk drying out on a foul bottom up the Cut.
Peter.
