Bridge Height.
Has anyone had experience of using a Flybridge Boat on the Norfolk Broads?Can you get through the bridges at Yarmouth to get to the Northern section?
hlb
RIP
Any Pub Lancashire or Wales
Well others will be better informed than me. But I have had 25 holidays on the Norfolk broads, and I have a fly bridge cruiser, unfortunatley the two never met! All the hire craft are made especialy low to go under the bridges. Yarmouth would be the first hurdle IMHO. Course it dependes on the tide and the boat in question. Short answer is though, sorry yer not going very far!!
Haydn
There are plenty of large cruiser's on the Southern section as Broom build them at Brundal but this may not be a large enough cruising area.It's the bridges through Yarmouth near the Yacht Station that would appear low and do not open!
grahamjd.
Yes I know and some are very low.Could always launch the dingy to explore those bits!
grahamjd
trev
23 Jun 2001
London/Home Counties/Middle East
You can pass through Lowestoft (Mutford lock) and into the broads with no problems except swing bridge delays. Then there are some railway bridges which will open for you on signal (give 'em a toot).
The main problem is the bridges to the northern section (Wroxham, Horning etc)
at Great Yarmouth. You must get there at dead low water, and with an air draft of around 12ft 6ins you can usually get through. There are height boards at the bridges and combined with the tide tables you can generally predict the best time.
The folks at Yarmouth Yacht Station are helpful and worth a call. I have been through on a Sealine 310 flybridge but had to take the small anchor light mast down.
The same low water approach applies to the Haven Bridge at Great Yarmouth.
Trev
lyc
30 May 2001
Norfolk/Suffolk
On the Northern Rivers at Yarmouth you would have to check the low tide heights and make sure you time it so that you can get back out.
I can struggle at Yarmouth end with 10'9 airdraft and have taken off the radar to get through.
Forget the river Ant the bridge at Ludham is too low.
bernard_foster
Bridge heights
Are as follows at HW normal tide
Acle 3.66m
Beccles old 1.98m
Beccles new 4.24m
Breydob fixed 3.96m
Breydon lifting 3.50m
Ludham 2.60m
Norwich Carrow 4.27m
Norwich foundry 3.05m
Norwich railway trowse 2.47m
Oulton broad mutford 2.40m
Oulton Broad Lake Lothing 4.57m
Potter heigham new 2.36m
Potter heigham old 2.03m
Postwick viaduct 10.67m
Reedham 3.05m
St Olaves 2.44m
Thorpe Railway 1.83m
Wayford 2.13m
Wroxham Railway 4.57m
Wroxham road 2.29m
Yarmouth Acle road 2.13m
Yarmouth Haven 2.90m
Yarmouth Vauxhall 2.06m
Hopethis is of use
