Breakback trailer
The pivot (usually just in front of the forward axle) allows the backbone of the trailer to hinge, once the catch is released near the hitch. The rear end of trailer then dips toward the water under the weight of the boat and makes it easier to slide the boat into the water. The key advantage of this approach is that you do not have to immerse the wheel bearings in water. Also you can use slipways with a short drop-off.
Obviously, for retrieval a winch is necessary....
On the one we use, the initial lift out is something like 30deg. Without a winch it would be impossible unless the boat was very light, in that case one would not need a breakback. After the boat comes forward enough for the weight to tilt it level, it gets a bit easier but still not without a winch.
A
I have seen another design, possibly not technically a breakback, which has a secondary lighter trailer running in beds on the main trailer. Again, I think the main advantage is that the road wheels are not immersed, only those on the secondary launching trolley.
In this design, the angle does not change, but the length of ramp is extended.
Whatever kind you have, a major improvement is to fit longitudinal guide boards either side of the backbone, and two padded guide posts at the rear corners giving just clearance for the maximum beam.
Before I was given this tip I had to make repeated attempts to get the keel aligned straight on the trailer, the tractor tentertively hauling it out only to discover the tide had pushed the keel squew-wiff. With guide posts to aim for and boards to locate the keel, it cannot slip off once engaged.
I use the dolley system for my Sunbeam (2 tons), winching the dolley onto an ordinary car trailer, or flat bed, using a shared trailer. This means I have better access to the boat for maintenance, and take up less space. I am very pleased with it.
Tyrone Snell trailers (near Falmouth) built it, based on their shore cradle design, which packs flat. The wheels are steel taken from the front support for articulated lorry trailers. No steering system is needed, but it can be skid steered with a long pole.
Iain Oughtred includes details of such a design with the plans for his Eun Mara. The first builder came up with the design. A feature is the use of double wheels, 8x4, at each corner, these give it slightly positive bouancy, which aides pushing it under the boat before lining up on the slipway. The boat in question is a bit under a ton.
I intend to use a similar system with a car trailer for my 1.4t trailer sailer. The trailer I can borrow or rent for the few times a year I need it.
A
