Dino
Hi,
I'm installing a dedicated bowthruster battery in the bow to power the 3kW unit in my boat. I am hearing conflicting opinions about what type of battery to use. I was planning on using a 100-115ah starter battery with high CCA but a few people have mentioned that I should use a leisure battery. Apparently the leisure battery will be happier to be depleted more.
Initially, I will have a dedicated smart charger to charge the battery when it is on shore power but I will add a DC to DC battery charger or a dedicated alternator once I get it set up. My boat is 24V but the thruster is 12V.
Also, is a 250A fuse suitable for a 3kW motor? Vetus use a 250A fuse in their 3kW unit.
Do I need a slow-blow fuse?
