clyst
Is it possible to fit a bow thruster to a wooden carval constructed boat ? Cant see its possible really but you lot may know different .
cheers
cheers
cheers
cheers
Always depends on the construction of the hull, but short answer to this question is yes you can. Are you thinking of doing so ?
Tom
I love that. Yes you can but its easier and cheaper to learn how to manouver the vessel correctly, bow thruster get outer here , man up .
You could try an external bow thruster:
https://www.absolutemarine.co.nz/images/products/Bow Thrusters/exturn_bavaria42_bow.jpg
There is another type though. It retracts into the hull, rather like the nose-wheel of an aircraft. This type would probably be much easier to install into a wooden hull with relatively less drastic surgery. Think along the lines of 'lift-keel' and 'centreboard case'.
I get irritated by this predictable reply. So I will retort with an irritating, predictable reply.
Bow thrusters allow manoeuvres that are impossible without them. Like going sideways.
Going sideways is quite possible, indeed quite easy, using wind and tide.
Bow thrusters make manoeuvres that are difficult without them simpler. And whats wrong with that?
Nothing, but neither is there anything wrong with practical seamanship.
Bow thrusters usually eliminate the need to spring off berths or rope out of berths. Hassle saved.
See above answer / comment.
Bow thrusters have a place in particular in long keelers in crowded environments. They allow you to steer astern, and keep control slower.
Steering astern etc. is quite possible, with a little bit of forward thrust!
If you think the only use for a bow thruster is to mask bad boat handling (which to some extent it can do), then you need some lessons in how to use a bow thruster.
Trouble is, it would involve cutting a chunk out of a fairly vital structural member (would "stem post" be the right term?). The bow of the boat would no longer be connected to the rest of the hull except via the planking.
What is wrong with a crew member in an inflatable dink with outboard motor?
By far the most effective kind of external bow thruster.
Okay, so you have a bow thruster and wish to defend your choice. There are those of us who take great pride in doing it the hard way!!
Was speaking to the supplier of such boys toys who openly admitted to me that he could not for the life of him understand why folk were fitting them on small boats! Personally I think that they are great for folk who need them / can't cope without them!
Sorry nonsense. I feel no need to defend my choice.
You are right they are great for folk who's handling skills are less good. They are are also an excellent tool for experts. I don't care where you think I am on that scale.
But I suspect you've never used one or learned properly how to use one.
