tgot
New Member
Hi all,
I'm new here (obviously), and I'm new to boat building and sailing. However, I have built myself a PDRacer and am at the point of building my mast and sails. My question is this: Is it necessary to have stays on a bowsprit? I'm only planning on flying about 55 square feet of sail area which includes both the jib and main on a 12' mast (above deck). The sprit itself is 4 ft overall length with the lower foot encased in tight housing running through the bow deck. It is made of a 2x3 piece of lumber from HD that I have shaved down a bit at the end. The forestay will just connect to a heavy bolt that I will run through the end of the sprit.
while i am no engineer, I'm pretty sure I have overbuilt the mast step, partner, and sprit housing (I don't know what the technical name of that is) and all should be more than secure and tight down there. But in your professional opinions, do you think that, given this set-up, I will need to run stays to the hull or bow? Thanks in advance for any advice!
Travis
Travis
