Bow or Bows?
Grehan
11 Jun 2001
Inland France + Oxon.
www.french-waterways.com
Apologies if this is a regularly debated old chestnut - I did try a search without obvious result.
It's in the title.
Is there a difference between 'bow' and 'bows' ?
I've heard/seen the two used interchangeably
Is there an Anglo/American usage difference?
I have a feeling they are the same, except I tend to think (eg) " . . the bow of the yacht cut through the water . . " (ie specific part of the boat) and . . " . . I'm going up to the bows . . " (a more general location).
In French it is 'proue' (prow) so I guess I should also ask about 'prow' which seems to me to relate to a smaller boat/dinghy . . ?
Anyone care to educate me?
BTW Same for 'heads' and 'head' . . . ?
TC Tuckton
8 Sep 2013
I thought "head" was a contraction of "cathead", the place in the bow of an 18th century sailing ship where an anchor was stowed alongside. This would provide a useful handhold when squatting outboard...
prv
29 Nov 2009
Southampton
I think strictly speaking the very front part that cuts through the water is the stem, then just behind that on either side is the port bow or starboard bow, collectively "the bows".
I would still talk about "the bow of the boat" though.
johnalison
14 Feb 2007
Essex
I think a boat has to be above a certain size to have "bows". I can't imagine referring to the front end of a pram dinghy in the plural, but I'm not sure that I could be entirely consistent on this.
ylop
10 Oct 2016
I've always understood prow to be the part of the bow above the waterline, I wouldn't particularly use it with dinghies or small boats - indeed I would be most like to use it when there is a significant overhang at the front - i.e. The waterline length is signifcantly shorter than the deck length.
superheat6k
10 Jan 2012
South Coast
The heads refers to the general area forward traditionally used as the ships toilet. A head in more modern parlance is a single WC trap amongst a group of 'Heads'. The traditional I was brought up with was 'Heads', as in 'I am going to the aft heads' except where just one was concerned which was then a head.
Prima
N/A
3 Mar 2017
Bow
1. The front of a vessel.
2. Either side of the front (or bow) of the vessel, i.e., the port bow and starboard bow. Something ahead and to the left of the vessel is "off the port bow", while something ahead and to the right of the vessel is "off the starboard bow." When "bow" is used in this way, the front of the vessel sometimes is called her bows (plural), a collective reference to her port and starboard bows synonymous with bow (singular) as described in Definition (1).
Prow
a poetical alternative term for bows.
https://en.wikipedia.org/wiki/Glossary_of_nautical_terms
Capt Popeye
30 Sep 2011
Dawlish South Devon
Humm might suggest that when indicating one's intended on board movement towards the front of the craft the term 'going forward' can be used, as going to the Bow just might be a move more forward than intended ?
As if one actually passes the Bow one is in the poo, or deep water, or even hot water, depending upon one's lat n long?
