sarabande
after lots of discussions and back-of-envelope scribbling, I now have two fairly substantial galvanised steel fairlead/cleats on the boat.
[/IMG]
That pic shows the previous mooring method, with two lines running through the single bow roller.
I know these fairlead/cleats are not elegant, but
1... I am used to solid farm engineering
2...the previous small stainless fairlead can be seen on the port side. Its friend to starboard was simply pulled out while the boat was moored in the marina in the January storm
3... the intended use is low-crewed cruising and anchoring
4... shortly I move to a swinging mooring in a moderately exposed SW river
Having installed the fairleads, I made the two mooring lines fast, one to P and one to S.
[/IMG]
The boat's Operational Review Policy Team took one look at the second pic and asked why I was not using the new cleat as a fairlead and making fast to the central cleat. The team manager was concerned that Pic 2 is not the best way to make the boat fast to the mooring buoy.
Some details:
1... the toe rail is 25mm thick GRP (the deck section and hull section are both 1/2 inch GRP layups).
2... The fairlead has a 10mm oak packing piece, and 5 x 8mm bolts through the toe rail upstand.
3... the central cleat is alloy, and I beiieve it to have 2 x 10mm threaded bolts through the deck with some (as yet undetermined backing piece)
My rough and ready instinct is that the Pic 2 arrangement is stronger than the suggested alternative (shown here in red)
[/IMG]
and I wonder if the red "mooring through fairlead to central cleat" suggestion is subject to confirmation bias, perhaps because that is the way it was previously.
I am genuinely after the strongest and most practical arrangement of the mooring lines, and seek the forum's views.
Please take it as read that the central cleat will be investigated for solidity of fastenings, and bigger backing pieces installed if needed. I am not averse to another central cleat, but am wary of genoa sheets getting trapped in uncovered cleats.
thanks in advance. T.
Some details:
