GregOddity
Nicely done. Very good points. But here are mine. I have a box of carbon cut outs that I cannot use for anything as they are too small and were the rests of parts I did. Yes, I have worked with Carbon fibre before. I also have quite a powerful Rietschle vacuum pump. Top of the range when I bought it 10 years ago and as expensive as a small car. I have experience with moulds from exotic silicones to lost wax castings. As the fibre is under the stainless it will minimise the impact of UV and temp. The stainless will act as a heat sink for any heat absorbed by the carbon. Slippery is also something that I anticipate as wet stainless is quite slippery on its own, but changing the round shape of the handle to a squarer section is an attempt to minimise both effects, from the carbon and stainless, as it provides a more stable grip, even when wet.
Since I have both the stainless and carbon, anything else I may buy will be more expensive then using what I have. I do need some resin as mine is too old. But for detailing a small amount will do.
A good tip is NOT to use ANY wood on a plastic boat. Wood needs care and loads of sanding and varnishing and rots as well.
Plus was it not fun making your pole?
