Boracol vs Patio Magic
srah1953
21 Jun 2007
Ireland, Carlingford
A different question on teak cleaning. Does anyone know what the difference in performance is between Boracol and Patio Magic? Patio Magic I can buy locally whereas Boracol will incur significant postage charge.
Stork_III
6 Aug 2002
Here and There
Borocol is probably better, has a Fungicide and Algaecide, PM has only the same fungicide. But for the significantly lower price and ready availability PM does everything you want it to do. Neither restores the teak colour.
maby
12 Jun 2009
Patio Magic users seem to be very happy with it. Boracol may last longer, but it is a lot more expensive. Thus far, we have used Boracol, but I recently picked up a small can of PM to try - ask again next year!
FWB
N/A
29 Feb 2004
Kernow
Have never tried Boracol.
I have used Patio Magic once a year for many years.
This is AFTER one year....
maby
12 Jun 2009
Mix 4 water to 1 PM. Spray on dry teak with garden sprayer, leave and don't touch again. It's magic :)
I prefer to brush it - it is quite toxic to marine life, so it is just responsible to do everything possible to minimise contamination
maby
12 Jun 2009
I spray it on the teak not on the sea.
Unless you are using a model maker's airbrush, it is pretty difficult to spray right up to the edges without some overspray! I can cover a lot of teak very quickly with a decent size brush and no run-off into the marina.
FWB
N/A
29 Feb 2004
Kernow
It goes on the teak, not in the water. Can't see your problem.
Mistroma
22 Feb 2009
Greece briefly then Scotland for rest of summer
www.mistroma.com
Active ingredient is extremely toxic to marine life so brushing helps minimise run-off (+ cheap and quick). Best to apply pre-launch where minimal run-off would probably bind with clay in soil or at least take a longer route to the sea. Only apply in dry conditions to give it a chance to bind to the teak instead of just washing off.
I last used it about 2 years ago and will probably brush on some more this year as I can see 2 small greenish spots developing.
dje67
20 Sep 2007
Largs
I've used both over the last 5 years and couldn't see any advantage of one over the other in terms of keeping the deck very clean looking. As per the lovely photos earlier in the thread, it keeps the teak almost white with no need to do any cleaning whatsoever.
srah1953
21 Jun 2007
What I find curious is that people show pictures of a clean deck after a period of months or a year (whether treated with boracol or PM), whereas on my boat any surface that gets walked on gets quickly dirty, either from shoes or dirt in the air.
maby
12 Jun 2009
I do wash the deck periodically with mild soap and a very soft brush, but that alone will not keep teak clean. A lot of the dark stains that develop on any unvarnished teak are mildew and you need a fungicide like Boracol or Patio Magic to clear that.
charles_reed
29 Jun 2001
