Ian_Edwards
I need to take the boom end fitting of my Seldon boom to replace the reefing lines. The boom end fitting is the usual cast aluminium.
The Seldon Website shows the boom end fitting is retained by four M6 CS set screws, however the previous owner has replaced the set screws with pop rivets.
I'd normally drill the head off the pop rivets and punch the old rivets out, but I'm wondering if the pop rivets will have expanded into the original M6 threads, making them difficult to drift out.
Can any one make a guess as to whether this is likely to have happened?
The alternative is to drill the rivets out and then use a Helicoil inserts. Is this likely to be successful?
I don't want to put the boom end fitting back with pop rivets I really need to be able to access the single line reefing system without having to resort to a drill.
