flaming
My “offshore” preventer solution can be set once, with the main centred, then operated entirely from the cockpit including gybing.Very true. Trouble is with most boats is that you’re often below boom level in the cockpit but very much in the line of fire when going forward on the side decks. That’s the trouble with preventers - you have to go forward to set them up. I like Roger’s setup because it’s permanently there and ‘switching it on’ just involves tensioning a line led back to cockpit.
Basically you have a line running from the main sheet attachment to the bow cleats, or block if available, and then back to the cockpit, on both sides. Tension when in use, and if led to a winch you can even ease it through a gybe. The rolls Royce solution has a split line with both parts joining half way.
