scruff
Last year, as usual, my log stopped working after the first couple of weeks due to fouling.
This year however, I intend to remove the log at the end of each sail, and replace with a blanking cap. I would however like to fit a 6" pvc drain pipe vertically around the fitting inside the boat to contain the water which will invariably come in during removal. I know it is not a lot of water, but it runs off to the bilges and is quite hard to get at to dry it off.
The question is however, what would be the best method of bonding said PVC pipe to the hull? would some epoxy do the job or would it be more of a sikaflex job?
Answers on a post card please....
Thank you
Thank you
