I see what you're saying, Nigel. A line through the luff reefing cringle would bear down on any slugs stacked up beneath it. That would be the same with our setup. I sort of feel there ought to be some solution. I'd love to be able to reef from the cockpit, but having cockpit controlled lines then having to go to the mast to pop the slugs in or out defeats the purpose. I need to fiddle around with some arrangements once we're back in commission.
By the way, how to you run your clew reefing lines?
I have to admit to a stack-pack sail cover - a bit chequebook-sailorish, but it makes life easy which is what I need right now. That covers the untidy bit at the front where the slugs pile up like in your second picture.
How ? Its simply a line about 6mm braid that is passed through and halved ... ends taken back to original boom end fastening and then back to cringle to pass under boom to hold it down. Actually I do it different each time .. but that's the gist ... first it pulls back to tighten sail horizontally .. then down to clamp to boom.
Tack is same but passed under and round gooseneck ... nothing fancy at all. The lines are never left in sail either .. only used when reefed.
No blocks, no cunninghams, no special fittings at all.
I am considering removing the gate next time .. I have a plate about 4 in long and 3 in wide that has a thumb screw and elongated hole to allow it to move out of way for slugs to exit ... but its not been used much by previous or myself. So needs cleaning up. That way I can possibly start to clean up the stacking / reefing bit.
I was going to add an SBC style Lazy Jack DIY system ... jokingly called Lazy-Jims .. after my mate Jim prompted me to sketch one up for him ... total cost about a fiver ! Never got round to it ... maybe one day !
