laurie65
I have carried out tests on a 2 ton life boat she as a saab 12 hp diesel 1800 revs into a 2 to1 gear box the bollard pull with the boats own propeller was 16 inch by3 blades pulling 180 kilos at 874 revs at 12 inch of pitch on the screw. I have my own propeller designed prop that I have also tested the bollard pull was 220 kilos a the revs was 849 r,p,m, this prop is only 15 inch by 3 blades both props are about the same bar size as any one what I should do next to get this known to all boat users I need held I have photos of the test all carried out in a closed dock here in hull.I should add that both the props are open no nozzle is on the boat I need help from someone with a boat that I can use to just finish my tests as I want to take a little pitch of my watertrap prop to match the boats prop this pulls more with an open prop than if it was fitted with a nozzle ...
