Boathooks
Luanda
Active Member
20 Jan 2004
Copenhagen, Denmark
Can anyone remember in which issue of PBO or YM there was a survey of boathooks, especially the type which can attach a line to a buoy? I believe it was 5-6 months ago, but can't find it.
<hr width=100% size=1>
Home: WebShop: Anchoring & Mooring: Boat Hooks & Mooring Accessories:
Moor Fast - The Complete Mooring System £39.95
Moor Fast threads rope through a ring or around a cleat up to 2m away with a simple push-pull action. Quick.Safe.Secure.
Boat owners know that mooring can be difficult, particularly if you are on you own or short-handed. The wind may be blowing. There may be a couple of knots of tide running and you are trying to get onto a mooring that may be unfamiliar to you. You need to be able to do this first time, every time. We all know that there are products on the market that can help, but do any of them work as easily as MooR FasT.
MooR FasT works with buoys, pile moorings, marina berths and locks. In fact, almost anywhere that you need to thread a line through or around. The shape even allows you to lift up a pontoon ring and thread your line under it.
Built to last in a marine environment.
MooR FasT is manufactured from hi-tech materials and built to last in a marine environment. The design has been carefully researched and tested in practice by boat owners for ease of use. The ergonomic telescopic pole is made from a high-strength, light weight composite material and halves in length for easy stowage.
IT FLOATS! MooR FasT's distinctive colour is highly visible and it will float if dropped overboard.
Click Here to visit the Moor Fast website: www.moorfast.com
© Seamark Nunn Ltd All rights reserved
I thought you'd been practicing morse code on the Ctrl V buttons /forums/images/icons/laugh.gif
<hr width=100% size=1>There is no such thing as "fun for the whole family."
Mooring Aids
We did a test on mooring aids, boat hooks with out hooks, in Dec 03
The swiftie-matic was the cheapest at £28
The moorfast had a life time guaranT £39.95
The mooring mate was £35
All the above pretty similar
The handy duck was simple, tough and easy to use £56
hope that helps :-)
