LadyInBed
Background: Our moorings were re-laid and re-spaced (moved closer together) last winter.
After this they dragged and moved from the river bank to the middle of the river.
The Environment Agency have been in communication with me:
I replied:I have undertaken maintenance on your mooring. It has been move back into the bank where it should be.
Can I please ask you to turn your boat around to face the correct way with the bow facing upstream. The boat is putting too much strain on the mooring when the tide is running off as it forces the stern of the boat out into the river. This is part of the reason the mooring has been pulled out into the river.
Can you please attend to this asap.
EA replied:Thank you for your information.
Regarding which way round my boat points, I would totally disagree that "This is part of the reason the mooring has been pulled out into the river".
I have pointed down river approximately 80% of the time in the Thirteen years that I have been on the mooring !
The moorings did not move in all that time up until the recent re-spacing and re-laying of the moorings.
If one boat on the trot can have the effect you suggest, then I would have serious concern on the quality of the moorings that were re-laid!
If you are the person that I have spoken to several times in the environment agency boat, not once have you raised the question as to the direction that my boat points.
The reason I mainly point down river is for ease of departure as I sail mainly single handed.
My reply:Thank you for your reply.
I have been watching how your boat lays on the mooring for some months and your boat is prone to pulling out into the flow when the tide runs off because the flow is hitting the stern and also the rudder, once your vessel is across the flow it starts to turn the vessel above you and so on.
It has not always faced down stream, this has only become more prevalent this year, I have had to move your boat for maintenance on many occasions over the years and it is the only this year I have had to do it facing down stream.
There is no issue with the moorings being relaid there are several factors that caused movement this year the weather being the major factor. They have been re spaced for operational reasons.
I still require your boat on that mooring to be tied up facing upstream as with the rest of the boats on that section.
If I can determine that there is no difference in the way your vessel lies when the tide runs off or in high river flows then I will look at it again.
We will not be re spacing the moorings. If the mooring moves again with your boat facing the wrong way I will look at weather your boat will need to be moved to another mooring.
Do they have a case?" I have been watching how your boat lays on the mooring for some months and your boat is prone to pulling out into the flow when the tide runs off because the flow is hitting the stern and also the rudder"
So have I, that is why:
a) I have, and always have had twin mooring lines, one to each side of the stern.
b) My rudder is positioned to counteract the current flow on the ebb.
I have also observed that the upstream end of all the boats tend to rotate out when the tide starts to ebb, especially those with longer mooring lines.
" this has only become more prevalent this year"
That is more to do with the moorings shifting themselves to mid stream!
When the moorings shifted position, I was away from my mooring cruising in Brittany.
I returned to find that they had moved position and commented so to the boat moored down stream of me.
" I have had to move your boat for maintenance on many occasions over the years"
I think you are confusing my boat with another! On a visit to the boat, the first thing I check is the mooring lines and it would be obvious to me if they had been retied by someone other than me.
My boat has been moved when I have been informed that maintenance was required, but I was always moved by me.
" I still require your boat on that mooring to be tied up facing upstream as with the rest of the boats on that section."
Next time I visit the boat, providing conditions are favourable, I will turn the boat to face upstream, but this is only out of courtesy as there is nothing in the mooring T's & C's to say that boats can only be moored facing upstream.
" If I can determine that there is no difference in the way your vessel lies when the tide runs off or in high river flows then I will look at it again."
I think you should also address the fact that it was only after the recent re-laying and re-spacing that the moorings moved.
They didn't move after the previous re-laying was carried out.
"If the mooring moves again with your boat facing the wrong way I will look at weather your boat will need to be moved to another mooring."
This sounds a little vindictive, I hope you will take into account (as stated above) that I wasn't on the mooring when they shifted!
