moresparks
I am in the process of replacing failed old twin engine sterndrives with a brand new modern single engine sterndrive in a budget cruiser and the overall HP will be similar.
Before anyone comments … I have already gone past the point of no return!
The modification work to the transom is considerable, but to make the project viable cost wise, I was hoping to undertake most of the work myself.
It means completely removing the inner ply “core” and replacing with a new Marine Ply Core. The new core will be 2 times 18mm ply shaped and bonded together. Finally tabbing and fairing the old twin sterndrive shield holes and cutting a new centre hole for the new shield.
The old core has now been removed and the outer skin all left intact and the surrounding area made good and reinforced where necessary. As the old hull was built with polyester resin, all new work will be undertaken with Lloyds approved polyester resin to be compatible.
The next stage will be to “bond” the new transom core to the outer skin (from the inside) with thickened resin, then the transom core will be “tabbed” from inside using and layers built up to the required thickness as specified by the engine manufacturer.
Now my question…
So far I have undertaken all the non technical (heavy labour) work myself, but do I HAVE to employ a specialist fibreglass technician to bond the new transom core into place for insurance purposes?
I am waiting for a response from my insurers.
I am no stranger to fibreglass work having been in the past on fibreglass courses and undertaken various projects such as fitting a new diesel inboard including bearers to a boat and fitting a sail-drive in another.
The reason for asking is timescales in trying to get a technician to schedule in the work as I have already waited several months, also costs as I am on a tight budget and the weather / temperatures are on the rise.
The finished work will be surveyed in accordance with the Insurance.
I am hoping to get answers from some who have done this type of work in the past.
Thank you…
Now my question…
Thank you…
