jfm
jfm, I dont know whether its been mentioned on the thread but did you consider fitting the Seatorque shaft system http://seatorque.com/ in your new boat? At SIBS yesterday, we happened to get talking to Tony Fleming and he's now fitting them to his 55 model and he reports a 1 - 1.5kt speed increase compared to standard shafts which on a 15-17kt boat is quite a significant efficiency improvement.
New boat looks fab. Will I be able to tramp all over it at LIBS or Dusseldorf 2011?![]()
I had a good look at the fleming 65 at the show and saw the SeaTorque system.
It wasn't feasible to include them on my boat. I was ordering the boat literally 2 weeks before the hull went into the mould and Fairline were about to order all the P brackets and shafts within literally a few weeks. There was no time to review the engineering of fitting SeaTorque, especially because Fairline's engineering team had to run off and do the engineering work (with Olesinski's help) to design the stabiliser installation, and they had to include the hull reinforcement as the hull was being moulded, obviously, so time was tight. There was no time to consider SeaTorque, purely for these practical reasons
I'm slightly sceptical about SeaTorque. There is less drag because you are dragging a stationary cylinder thru the water not a spinning shaft, but that cylinder is bigger diameter necessarily. So it's kinda one step forward and one step back, intuitively. If there is some science behind why there is less drag I'd like to see the proof. Some fluid mechanics maths would do the trick. But it's marketed like ultrasonic a/f, which is "it works and you just have to trust us".
As for claims of 1.5kt I'd want to know the conditions. Same boat with SeaTorque retrofitted, or two different hulls of the same boat series? etc.
