Forbsie
I can't stand the wait!!!
Could you ask Fairline to install a webcam so that we can get our daily fix?
Geez, that's picky! The GRP surface surrounding the actuator doesn't actually look bad at all, judging by the pic!Port stab actuator installed. Bit unfair on Fairline to show it like this - the whole surrounding will be nicely finished when it's done
Interesting to see the assembly building is a bog-standard crinkly tin, shallow-pitched roof job. Bet it leaks like a sieve.
I love to see marine engines installed and look at the way all the fixings and cable runs are secured. I see that you have had Cats installed. Did you have different options of engines that could have been installed?. Can you give us a brief run down of how you chose these engines. Apologies If this has been asked before, what page.
David
The engine choice was easy. They are tooled up (with engine bearers worked out, I mean) for the Cat C32 and the MAN1360. They may also be able to do 1550 MANs but I didn't even ask because I am not a fan of MANs; too many first hand stories of major failures in boats - I made a post on this the other day. In contrast the Cat C32 is apparently bulletproof; I can find no stories or internet mention of any significant failures.
The Cat C32 comes in various HP versions up to about 1900. Fairline strongly recommended the 1572 version, because going bigger means bigger p brackets and shafts and you lose the extra hp in drag, and the boat is already fast - 34 kts on the 1572hp version. And best of all, the Cat C32s at current FX rates are cheaper than the MAN1360s (MAN is German, Euro priced; Cats are made in South Carolina, USA, so $ priced).
When faced with 1360 MANs, or 1572 Cats for £50k less, it really is a no-brainer
To my mind, when speccing a boat like this, it has to be MTUs or Cats
Whilst I fully agree on the brand, if given a choice between Cat and Man, I'm actually surprised by FL recommendation of the 1572hp version. In fact, I had a doubt which I just checked on the Cat selection guide:But certainly looks the engine of choice.
Dunno what FL reasons are, but the fact that they're the only reliable measurement of tanks levels known to mankind is a good one, in my books...!Do Fairline fit sight tubes to the tanks because they're definitely worth having?
The 1572hp is the non-Acert version, E rated, RCD compliant.
Nothing wrong about it, but they also offer these alternatives:
1470hp, C rated
1622hp, D rated
Now, having the same block in a higher power/higher rating and a lower power/lower rating version, that's something which already raises the question of why they're still producing the latter.
But what's even more important is that the two above alternatives are both Acert, IW/CC2 compliant, and WOSR capable.
On paper, that's a perfect fit for such vessel, considering also the usage jfm has in mind...
I'm really interested to hear what the rationale behind FL "strong recommendation" was.![]()
Are the Racor 1000 duplex filters standard fit or did you request them? I like Racors as they are a good filter thats also easy to change when under way with no mess but others on this forum seem to have a major dislike to them, whats your view?
If top is going on soon does that mean dashboard will be aswell, do they fit plotters yet or do they wait in case something new comes out later in build?
