Cardo
That's an impressive bit of kit.
Stunning,
I thought you would have said sod work and be out playing with your new toy![]()
The Maretron displays anything on the n2k netwrk but it does 4 things that Garmin (and Furuno, Raym, Simrad, etc) won't do, namely (1) it shows sentences the others wont support like "watermaker on"; (2) it allows user-composable labels so you can type in "electric seacock open" if you want; (3) it allows user to program device instances eg if you have two "generator on" sentences you can use the Maretron to program one as port and one as starboard; and (4) it has a moonphase/sunrise/sunset calculator page which makes for a nice/funky display. I therefore find it useful to have one Maretron in amongst the Garmin stuff, to access these features. It is a DSM250 colour display. I have another one but haven't decided where to put it yet because I've run out of room at lower helm!What's the Maretron display for?
Here are a couple of geeky updates. First, here is the new Garmin 8000 glass bridge kit all installed. This is the first big end user/retail customer install of this kit in the world. On the flybridge, the new small "GMI20" instruments that replace Garmin's previous GMI10s have been installed flush mounted, in a line of 5 instruments. This was done by getting a new aluminium panel cut by Axon Components, Fairline's OEM supplier, to replace the panel that was installed on the boat when built. The new panel was CNC cut using .dxf files supplied by Garmin, then painted metallic charcoal, all by the excellent Axon. The instruments look fantastic mounted this way. The two big screens are 8015 touch screens with iPad style pinch to zoom etc, and in total there are 6 of these 8000 series touchscreens on the boat
The GMC10 autopilot controller, bottom left of steering wheel, will be replaced by the new GMC20 version this week - the new controller just arrived from Garmin
The boat has bonded square flush windows like this...
... but the window in the transom door was a standard screw-in hatch from the Lewmar catalogue, pictured below, complete with visible "joint" in the bent ali frame extrusion, urgh!
I hate the Lewmar hatch so Allen and Andy, the two GRP maestros at EssexBoatyards, changed it. They made a couple of plugs, then moulds, then GRP components, and cut-n-shut them into Match2's transom door, both the inside and outside mouldings. Phoenix Special Projects, Fairline's OEM window supplier, made me a one-off bonded window, in custom size and fritting, which Allen and Andy bonded in, to produce this beautiful job. This is a really nice piece of craftsmanship, with beautiful GRP fuinishing inside and out. You cannot see the cut-n-shut joint at all and the whole thing looks like it was made this way orginally. I'm really pleased with this mod, even if it is a bit OCD
I think that new hatch/cover could be the single most important mod of them all. Not only is it absolutely striking (match, geddit?) but it will be the first thing anyone sees as they wander down the quai when you are med moored.
I must admit that I have to agree with MapisM on that one. (no offence intended)I think they make the Sq78 look like they coupled the hull and the superstructure of two different boats
