MapisM
Ok guys, I'm looking for opinions and ideas on a boat design issue, which in turn also affects functionality.
In the two pics below is shown firstly the existing boat, with a s/s boxed radar arch which is the one the boat was built with.
Arguably not the nicest choice for a wooden boat, but it's already there and does its job.
Below is a rough drawing of an hard top job which is being evaluated.
The obvious advantage, aside from getting rid of the arch, would be having some shade on the FB, still leaving a wide aft space for sunbathing, and the possibility to enclose the FB with front and side canvas, and also cover it completely when the boat is not used, with some further canvas astern.
BUT, it's much easier to draw it than make it.
The cover structure has to be roughly 10'x 13', thus requiring quite some strength (hence also weight).
The idea is to use 4mm alu for the cover, slightly curved along the beam, with some alu tubes underneath, all around the cover and along its beam, at 2' distance each, to strenghten the whole surface. The pillars on the aft side, which should appear as a sort of prolongation of the main deck pillars below, would also be made of alu (boxed), and the whole structure should be painted in white.
The front supports would be 40mm polished s/s tubes.
Wadduthink?
Any view/proposal/idea will be highly appreciated, because before going ahead with a job which is neither trivial nor inexpensive I'd really like to evaluate all pros and cons.
Many thanks in advance!
Wadduthink?
![RB-HT.jpg](/proxy.php?image=http%3A%2F%2Fi23.photobucket.com%2Falbums%2Fb380%2Fmapism%2FANT%2FRB-HT.jpg&hash=4b024e9e982f2155e8a0630bf8cde879)
