boat brands - prejudice or reality
I’m afraid that I am something of a purist in this regard, and I tend to think that designers should design boats fit for their purpose, and that owners should be using skills rather than short cuts. It’s a bit as if we all had self-parking cars and that there was no one left who could parallel park.
I would disagree with both you and tranona. For me, a boat has a bow thruster when it is a poor design with too much above the water and poor underwater appendages . For example, I once drove a Vancouver 38 Pilot which despite its long keel needed a thruster both going forwards and astern when parking. I had a bilge keeler with a very similar issue but no thruster and very high topsides. Against that a Starlight with the deep fin could be parked anywhere with ease as could my old Prout cat with the saildrive leg. Latter took a bit of learning mind you.
Don't confuse the ability to steer straight, light helm or responsiveness with fundamental directional stability. Sirius Yachts supply a range of keels, this is what they say about their longer chord choice:
"........ While this (greater length fore and aft ) gives the boat better directional stability, it does make her a little less responsive and a little slower to manoeuvre."
Sirius make some lovely boats - though Geem won’t like them due to their huge hull windows.
But the vast majority I have seen have been bilge keeled. So not sure I would treat Sirius as top design authority on fin keel designs.
Here is someone else who is no doubt wrong:
A splendid example of what happens when Zealots get 12 uninterrupted minutes of airtime to present their own prejudice posing as theory. They choose only that which fits their theory ignoring anything that does not. Exactly what Karl Popper warns against, but is ignored by many.
The title is misleading. Not once does he say that poor handling of modern boats is caused by twin rudders, but quite correctly it is the result of wide stern sections that might lead to unbalanced waterline planes when the boat heels, upsetting the balance between CE and CLR plus on some causing the rudder to come out of the water leading to aeration and loss of power. So far, so good - he has read pages 1,2,and 3 of the basic introductory chapter on the forces that affect sailing boats. In fact he explicitly states that his objective is to explain how these forces interact.
The rest is just hyperbole or just plain wrong. Twin rudders are part of the solution to the negative aspects of wide sterns. They do not come out of the water - that is the whole point of having a rudder on either side. The rudder on the leeward side is always deep in the water (again listen to Chris Rassy). Fortunately designers and builders have also read the introductory chapter and look for ways of restoring balance inter alia by changing the forward sections of the boat to improve the basic hull balance when heeled, chines to control the water flow from the transom, moving the rudder post forward on single rudder boats, sometimes raking it backwards to keep the working part of the rudder as far aft as possible, chines at the bow, rigs that do not rely on overlapping headsails and of course twin rudders.
As to evidence that such boats perform negatively in the way he claims he offers none. He simply states that they will perform badly, but you may have to go to Patagonia to find out. Despite claiming a lifetime of ocean sailing he is unable to offer a single shred of first hand (or even second hand) evidence of this negative behaviour. No "I have just sailed one of these boats in testing conditions and struggled to keep control and it wore out the autopilot" or even "I met a bloke in a bar the other day. He had just delivered one of these boats and told me how awful it was". He does not need to go to Patagonia to find out how these boats behave. I was on the Cobb in Lyme Regis yesterday. There was a brisk SE wind making it a lee shore with a long fetch. Nice white topped waves rolling in and bashing against the sea wall. A west-east passage across Lyme Bay particularly against a spring ebb would tell him all he needs to know about heavy weather handling.
It is pointless trying to compare boats designed in this way to older style boats as they are fundamentally different. As I explained earlier I have owned boats from 3 design generations, The old long keel Griffiths designs, a wide stern J&J from the early days and a Farr design from just before the latest chined/twin rudder iteration. Unfortunately I missed out on the 70/90s fin and skeg loved by many as clearly they were a vast improvement on the long keel types in most ways, but I bought the Bavaria 37 rather than the Moody 376 I lusted after until I actually tried one after sailing a Bavaria 42. The Bavaria did indeed exhibit some of the negative characteristics described earlier. It was not helped by having a shallow keel and rudder plus lots of top hamper with a bimini and a large overlapping 135% genoa. So just as our youtube friend says it rounded up as it became unbalanced when heeled and the rudder lost control. Solution was to reduce sail area and keep the boat more upright. Owners of sisterships with the standard deep keel and rudder and reduced headsail size to 110% report none of this. The 33 with its mainsail orientated fractional rig, fuller forward sections, even wider stern and aft raked rudder had none of the negative characteristics of the 37.
Development of cruising boats goes in cycles with a step change every 15-20 years or so. Easy from the preceding paragraph to identify those step changes - 1970s, 1990s 2010. At each step change the new design direction shows flaws which get progressively eliminated. The latest super wide bodied boats which have become dominant in the last 10 years or so have followed the same pattern as designers have learned partly from racing how to eliminate the negative features of the fundamental architecture while retaining the non sailing features that buyers enjoy.
I would disagree with both you and tranona. For me, a boat has a bow thruster when it is a poor design with too much above the water and poor underwater appendages . …
Each to their own, but I want a boat with underwater profile to give good sailing performance. I don’t believe that you can accuse Arcona, X Yachts, Maxi, HR etc of “poor design” yet most will have (probably retractable) bow thrusters above about 35 feet, and nowadays possibly stern thruster also above 40 foot.
You could argue that being “purist” should not have a bow thruster - but by same argument should not have engine, and be sailing on and off anchor and moorings (no such purist would surely approve of a marina pontoon).
Meanwhile I prefer to use tools to de-stress manoeuvres
I regularly sail a friend's southerly 110 with twin rudders.
The bow thruster makes marina berthing a doddle and makes the boat fingertip controlable.
It is too heavy to ever be considered a fast sailing boat but the twin rudders certainly help when heeled over.
It is rare to see a boat over 34 foot without a bow thruster and you can see why.
P.s. i can see why the more modern twin rudder southerleys have a bit of a cult following.
Seems to me to be analagous to power steering and automatic gearboxes in cars. They used to be a bit nasty. Power steering destroyed feel, auto gearboxes were slow, clunky and sapped power. But wider tryes and heavier cars really needed power steering, and a certain famous rally car with a diminutive but highly talented French lady behind the wheel was probably the tipping point. Hers obviously worked. Gearboxes, led by increased number of ratios are more recent. Same car manufacturer showed the way (Odd considering they’re usually up your backside😂) Auto boxes are universal, slick, and who’d want an 8 speed manual? I’d love a retracting bow thruster, my boat is a pig in a cross wind. We have our strategies, but a thruster just makes it easy. Just like power steering, why struggle when you can go the easy way. If you want to show off, you do it tidily, a couple of well judged bursts, it’s still a real skill. It just doesn’t involve your crew flinging themselves onto the pontoon to get a line around a cleat before you clobber someone, and swigging the lines to bring you alongside. They just step off and make fast with no fuss. More drinking time, less stress, what's not to like?
Not quite perhaps bad design but a sticking plaster. With twin rudders many are happier with a second sticking plaster in the form of a stern thruster.
Plumb bows are a great way to extend the water line and save expense in a marina, except the anchor hits the topsides so you fix a bowsprit, there goes the marina savings. Another sticking plaster but at least the sprit can be used to fix the off wind performance lost with a small or self tacking jib, fit an expensive furling downwind code sail - another sticking plaster.
Twin rudders are a sticking plaster in the first place as are twin wheels. We can fix anything with first aid but it all adds complication, weight and expense.
Of course these boats are great in many ways but If you don't have a quarter or a million £ plus and want to be self sufficient in setting offshore the consensus is smaller, simpler. With as little draught as you can get away with, the minimum of bulbs, rudders and legs sticking below the boat. Find a boat with one rudder and a skeg + only complications that earn their keep; what you don't have can't break.
Apologies for posting this again but here is our old friend Martin Daldrop. He took his Bavaria 34 half way around the world, was dismasted one time and then later lost the boat.
In 2024 his spade rudder broke and fell off in the South Atlantic, the boat rapidly sank. Daldrop took to his liferaft and thought about a new boat, something:
"Stronger
Much more robust
An older design........
With a skeg"
An interesting and informative review of different ways of building boats. No problems with that. However just like the piece in post#85 it is full of prejudice. He starts of by saying he does not normally write about such things as they are not "interesting" to him. Bias or what?
Nothing wrong with his descriptive material as most of it is taken from what the builders say themselves. However he then goes on to make unsubstantiated claims about performance and longevity of boats that he does not find interesting. He clearly has a thing about keel stepped masts and ballast ratios despite the fact that lower ballast ratios have been a trend for 30 years, replaced by deeper keels with bulbed ballast and deck stepped masts are commonplace.
It would be useful if he provided real life examples of masts coming down, boats being overwhelmed by conditions, hulls breaking up, boats being unable to reach their destinations in adverse conditions and so on. I have no doubt he could find some if he tried but equally he may well find such examples are not restricted to boats of particular types or methods of construction.
I can be guilty of that. However, I recognise it and try and correct myself. Is it a symptom of old age grumpiness, or irritation grown by experience a life lived? Maybe folks have too much time on their hands, the devil makes work for idle hands, sort of thing. I don't know. My experience is that on a whole, this is a good forum filled with helpful advice.
I’m also guilty. 😁
"Stronger
Much more robust
With a skeg"
Remember though that this is an ex charter boat that took him 40000 miles across oceans of 10 years. A boat considered by some (from their armchairs) unsuitable for such use.
Until it sank 😁
Indeed - but that does not invalidate the satisfactory performance over the previous 10 years and 40000 miles.
You might care to reflect on the high number of structural failures and a total loss in the last Golden Globe event - all designs revered by some a the only type suitable for ocean sailing.
Meanwhile the majority go on sailing happily around the world in their modest production boats.
I am sure then that you would approve of the skipper of a 45ft steel mobo I watched come alongide the pontoon in a Norwegian Fjord. Not only sis he have twin screws and both bow and stern thrusters, but to make life even easier, he had a remote control for then all so he stood on the side deck and used both engines and thrusters to bring the boat alongside !
Impressive technology but sailing isnt about using technology to get somewhere is it? If you just wanted to get somewhere easily and fast you might use a mobo or even a helicopter if you were flush. Sailors pride themselves on sailing skill and I have frequently both anchored and come alongside a pontoon under sail alone. The old boys did it.
I guess it’s a hobby. Where most of our sailing is done, there are so many other boats it would be utterly reckless to consider coming alongside under sail. Our forefathers didn’t have that. Anchoring and leaving, we do that sometimes in the tri. Picking up swing moorings too, but I get a lot of practice at that, 3 times a week in a boat with no engine. It’s so routine here it’s not a matter of pride. You do it, or don’t sail. But why take the chance if there’s any serious difficulty, unless you have to? You don’t drill holes in stuff with a hand drill, you don’t walk 5 miles to a shop in the rain. Every single area of modern life is easier because of technology of some sort. Why is it so wrong to make your sailing life easier. Do you have a log line you use every hour? A hand lead, complete with tallow? Cotton sails, ratlines? Christ, taken to extremes you might ask if a dugout canoe is too modern.
This thread is reminding me of those conversations down a pub (or yacht club) where people compare how fast their car can go, its supersonic 0-60 time and the width of the tyres. Rather than appreciating the long term reliability, intuitive controls and enough ground clearance and tyre thickness to deal with normal driving.
The evidence from this thread is that pretty much any well chosen and well prepared yacht will satisfy its owner. And that modern build and design can offer a more technical build and enhanced performance.
Whether you want twin rudders, bulb keels sternthrusters, large sail area, large tankage, separate sleeping cabins, teak trim etc. is all personal choice and how you use your boat. Racing and going fast clearly benefits from new ideas. Extreme use creates more failure risks and events.
I have sailed over too many lobster pot lines around western UK coasts to ever consider bulb keels or twin rudders. That is my prejudice, not a design flaw. And I prefer a large engine and manageable rig versus scintillating light wind performance - a personal choice.
The integrity of build appears after several decades of use and its hard to rationally evaluate the merits of different brands or models - most will have some problems appearing (headlinings, electrics, keel bolts, teak decks etc). Its more about ease of repair or replacement than anything. Upgrade whenever you replace and you get a great boat.
The OP "barca nova" has it right in post #216 (!). Its about skill and choice, supported by technology as you see fit.
I hope the thread has helped answer his question, although we do seem a little light on surveyor input.
But not you, their biggest armchair advocate
You are obviously getting a bit upset on this thread.
The reason this debate in unwinnable, for either side, is that there is no doubt old and new are different, but there is also no reason why a modern, or an old boat like yours, would be unsuitable for the type of sailing you do. It's a preference and priorities problem, which for every person is different.
I couldn't understand why you seem so vociferously opposed to anything modern, until I found your blog.
Wild Bird Adventures
It's a shame it stopped because it is both entertaining and interesting. Many could learn from the content.
I've got great respect for those who buy a close-to-end-of-life boat and put loads of money and time into bringing it up to scratch, breathing another decade or more of life into it. Why not start some threads on here, based on your experiences? You could highlight issues specific to older boats.
As far as I can gather, the teak decks were leaking and worn out, so you removed them completely apart from re-doing the cockpit and coach-roof, filled around 2000 screw holes, glassed the decks "for strength" and re-bedded all the deck hardware which involved taking the interior headlining out to get to the underside of the deck. Great job, it needed doing. Let's hear about it, with costs, time, and other useful information like availability of teak, how to make a non-slip deck etc. You could even give your perspective to people thinking of buying a boat with a 30 year old teak deck - especially the bit about how it is less than ideal in the Caribbean heat.
The original solid windscreen was severely corroded and the windows crazed, so you removed it and replaced it with a sprayhood - getting a decent spray-hood/bimini arrangement on a centre cockpit isn't easy - you could give people tips on how to adapt a centre cockpit to hot climates, the vents for your portlights and hatches looked interesting too.
There was also the corroded mast support, which you noticed when the bulkhead started creaking. You pulled the floor up, and found you could poke a screwdriver through the mast support. Things corroding in the bowels of old boats are to be expected. The bulkhead sunk into the bilge and started creaking. This structural issue required a mast removal and a repair, pretty much what Sailing Fair Isle had to do with a similar problem. As I understand it, due to the prohibitive cost of a mast removal, you sanctioned use of a hydraulic jack, and had the mast jacked up to allow fitting of a stainless steel section in the mast support. In the process, this separated the bulkhead from the hull, so you and your lovely wife had to re-glass the bulkhead due to the extremely loud noises it was making as the hull flexed (requiring ear-plugs to sleep?) - in the process of making the repair, you had to remove a considerable amount of the interior. Sounds like a great learning experience to me, and not atypical for boats of this age. Would also be interesting to people on this forum considering an older boat.
Old boats come with these sort of problems, however you paint them as a solid, dependable, safe choice, bash modern designs, and consistently fail to concede the associated issues of buying an old boat.
There are sailors, who don't want the hassle, cost, stress or uncertainty of relying on a 40+ year old structure. After reading the blog, which was very interesting, I can only conclude that your dogmatic attacks on modern boats could in part be due to a bit of cognitive dissonance? It must be difficult to evangelise your boat choice, knowing all the issues you have had.
Anyway, you seem to be enjoying yourself, as are the owners of modern boats.
