boat brands - prejudice or reality
The original OP was talking about 34' although that focus has long gone. The last boat used to illustrate a discussion point was a Jeanneau 40i which has twin rudders and chines. There is not an absolute size determinant of when a thruster becomes useful. It all depends on the type of boat and the difficulties it presents that might be lessened by a bow or stern thruster or both. For example there is a Southerly 32 in our club which as you may know is very shallow and has huge topsides so despite being heavy at 7 tonnes it is uncontrollable without its thrusters. My current boat is 31' heavy long keel, last boat was modern 33' single rudder, immediate neighbours in the marina are a Freedom 33 drop keel, Southerly 110, drop keel twin rudders and Malo 36 conventional long fin keel. All have bow thrusters so that the owners (age range 76-88) can enter and exit their berths safely.
You may feel mortified, but why? It is simply not logical. If a bow thruster makes life easier for you and enables you to use your boat more and carry out arguably the worst bit of boat handling better dhy should you feel bad about or be bothered about what others think?
I’m afraid that I am something of a purist in this regard, and I tend to think that designers should design boats fit for their purpose, and that owners should be using skills rather than short cuts. It’s a bit as if we all had self-parking cars and that there was no one left who could parallel park.
Here is a little honesty test:
1) Give a few paragraphs on the advantages of a long keel, skeg hung rudder, low windage hull configuration
Marks will be given for the number of advantages you can think of and a short elaboration of each one, you should be able to identify about ten
If you can't or won't answer let us know.
As I own a boat like that (except that the rudder is keel hung) so I know the characteristics. To list "advantages" means a comparison so you need something to compare it with and that is a pointless exercise in the abstract.
The test of a boat is whether it is suitable to meet the owner's expectations. It is a personal choice and all the so called advantages which are actually characteristics you claim for old boats can be met by different designs. If you really want to go through such a pointless exercise then you have to list the pros and cons of different designs, not just cherry pick.
For example what you see as advantages - long keel, skeg hung rudder low freeboard I would see as negative. Long keel equals high wetted surface area, poor manoeuvrability, slow; skeg hung rudder lack of balance area leading to high steering loads when pressed; low freeboard hull, lack of space below, probably wet. Exactly the reasons why boats like that have not been built in any numbers for over 30 years. Their characteristics do not meet buyers' expectations.
Why do you think I or anybody else should be able to list 10 so called advantages? Is there a prize or is this some sort of test of whether you are "proper" in some way or other?
Maybe this will help you understand better. I have owned 4 cruising boats over the last 45 years - two that approximate to the type that you see as advantageous and 2 of the very opposite - modern fin keel spade rudder etc. I have cruised them extensively in all sorts of conditions in coastal and near offshore so feel pretty confident that I can assess the pros and cons. Far and away the best one for cruising from where I am - English channel and western approaches was the Bavaria 33. Beautifully built, robust, light and easy to sail, fast, comfortable and good accommodation and storage. Why did I sell it and buy a Golden Hind? Simple 2 reasons. First nostalgia and second a wish to do one last big project restoring a boat given that age and circumstances mean my cruising opportunities are limited. Remember though this is a boat that in the 1970s was a boat of choice for ocean sailing with over 35 recorded transatlantic passages and many going further. Compared with the Bavaria as an everyday cruising boat though it is rubbish. Slow, cramped, cumbersome, hard work, high maintenance. Nice ambience in the cabin though so good when moored somewhere like Shipstal Point in Poole harbour for the night. Glass of Islay single malt is a bonus.
You might say my kind of sailing is not the same as "bluewater" (although it did include across the Med in my 37), but if I had been able to do that I would not have chosen an old style boat - too many downsides plus by 2000 when I might have been able to do it many were getting old and for the same money or less one could get a new boat like a Bavaria Ocean 40. Fast forward to today the choice is different as there is an enormous range of capable boats, mostly built in the last 20 years from which to choose so no need to go back into the past unless you have rose tinted spectacles.
There is your honesty.
A real light bulb moment, for me, with regard to “seaworthy” hull design, was the first McIntyre GGR. Where the casualty rate of the (mainly) Rustler 36 fleet was high. Previously I had regarded them as the epitome of moderate sized ocean capability.Long keels, rudder on keel, low windage etc etc
I am following the progress of a fleet of Class40’s in the Globe40 rtw race. The scow bow boats have just completed the Pacific leg (having started from Les Sables in the summer). The sharp bowed boats are about to arrive in Valparaiso. The Class40’s being designed very much in the modern idiom. Chines, beam carried aft, twin spade rudders, light & cored (but calculated) scantlings, fin keels. Some scow bowed. All designed to plane.
So far the casualty count has been restricted to spreader damage, in the South Atlantic x1. And a double hit of a UFO followed by lightning strike x1. Both boats able to sail to port, make repairs and resume.
Gives pause for thought….
Looking forward to the Cape Horn / S Atlantic leg. Starts Feb 18th
But that is exactly what they have done - why on earth do you think they are "short cuts". The boats are fit for purpose - they do the job the owners bought them for.
Here we go again ………
A modern HR with twin rudders will be very directionally stable, and with modern sail handling systems (probably including at least one electric assisted winch and a bow thruster) a doddle to singlehand.
Here is someone else who is no doubt wrong:
Don't confuse the ability to steer straight, light helm or responsiveness with fundamental directional stability. Sirius Yachts supply a range of keels, this is what they say about their longer chord choice:
"........ While this (greater length fore and aft ) gives the boat better directional stability, it does make her a little less responsive and a little slower to manoeuvre."
.......Why do you think I or anybody else should be able to list 10 so called advantages? Is there a prize or is this some sort of test of whether you are "proper" in some way or other?.......
No prize but it might help to sort out if your arguments are of a fool or a knave.
PS
Can anyone else not pick out the advantages and disadvantages of differing designs? Really.
