Dockhead
20 metres of RG58/u will give you about 4dB of attenuation at marine VHF frequencies, reducing your power from 25 watts to 10 watts, not counting the connectors. That may be usable if the rest of the installation is very good and the antenna is very good, but certainly not optimal.Weird that Shakespear supply 20m of RG58/u with their antennas and don’t mention this.
RG8X is twice as thick and feeding connectors down a mast rarely works.
RG-214/u is only about 1.5dB over 20m, leaving you with 17.25 watts of power at the antenna. RG-8X is about 3dB so not dramatically better than RG58/u. And it's not twice as thick -- about 6mm vs 5mm. RG-214 is about 11mm -- yeah, it was no fun pulling it through my 23m mast.
You don't want to feed connectors down the mast, whatever kind of cable you use. Install the connectors after the cable is already pulled.
