SimonA
I have a BMC 1.5 engine on my boat. Recently I have had a new gearbox fitted, along with a new shaft seal, prop and other bits. My engine was not developing it's full power in gear and it was found the old gearbox was worn and the prop shaft was out of line.
Now this has all been fixed it seems the engine is still not developing it's full power.
The problems include the engine stalling when put in gear. This happens with the revs set to about 700rpm in idle, if the revs are increased to about 1200 rpm it does not stall but as soon as it goes into gear the revs drop down to about 500rpm.
When in gear it seems to take a while for the full revs to build up. I'm told it should develop the power instantly.
Out of gear it will rev fine.
The boatyard have suggested that it could be a fuel blockage / faulty injectors / faulty governor / poor compression. Having already spent a lot on the gearbox I can't really afford to change all of these.
Any ideas where to look first?
