BM1 reading 9 volts !!!
grafozz
11 Jan 2004
kefalonia ,greece
out yesterday and the BM1 started reading lower and lower volts , down to 7 volts !
checked batteries and both showed healthy 1280/90 after rest , engine starts fine winch runs fine everything seems to be running normally .
so I disconnected the inline BM1 fuse and stopped worrying ....
Is it a BM1 faulty or is there a gremlin at work in there somewhere ?
any ideas please ?
VicS
13 Jul 2002
any ideas please ?
Did it give similar readings on both house and starter battery , or is it an old one that does not read the volts on the starter battery.
was it giving the expected current readings
Did you check all the connections. Esp the fuse as that has often proved to be iffy,
grafozz
11 Jan 2004
kefalonia ,greece
Yes checked the fuse it was ok but I changed it anyway , both batteries are connected together not seperate house/ starter .
it is the more recent BM1
I will check all other connections today , thanks all
