D
Deleted User YDKXO
Guest
OK understood thanksThe Victron Multiplus and Quatro are nearly the same,
The Multiplus has 1 AC input, and 2 AC outputs,
The Quatro has 2 AC input and 2 AC output;
One input for shore power and One extra input for the genny,
One Output is the invertor output or supply from shore or genny or the sum of both
The Other output is only active when there is AC Voltage on one of the inputs, for connecting MapisM airco fe. (appliances that you never want to switch on when no AC available.)
I think at least when I bought my Multiplus, the relay unit was an optional extra. The whole thing wasn't very well explained to me when I bought it. To be honest, I don't think the installer I used in Croatia, even though he was supposed to be experienced with Victron, knew exactly how the Multiplus worked and certainly if he had told me that there was an option to buy a relay unit to start the genny in the event of shorepower failure, I would have taken it. In fact, it took me quite a long time to understand how the thing worked and to find my way through the menusBoth units have a programmable relay, fe for alarm, or switching on a genny
Again, the installer didn't tell me about this and I don't remember seeing anything referring to this in the manual but yes it would have been very useful to check the voltage setting. On the other hand, I did have both a Battery Monitor and Blue Power controller fitted but again I don't remember seeing anything in the menus allowing the invertor to be switched off below a set battery %1) The units can be programmed that they switch off when battery voltage goes below fe ..12,3V , probably this Voltage was set too low in your unit (programming is done with dip switches inside or connecting a laptop)
Again I didn't appreciate that. I thought the invertor was just off in this positionINVERTOR – OFF – CHARGE ONLY, the latter position is typically for when you’re away from the boat for a long time, that loads on the invertor output are switched off when no AC power available, the loads can’t empty your battery’s through the invertor.
