SailingEcosse
Active Member
Final (ish
) update on this thread for anyone thinking about doing the same thing, parts required and money spent.
Hopefully this will save others some time and money if going down the same route
Pics of equipment used:
Vacuum pump - small twostage, 3cfm pump
Silicon heat mat - Gotherm 2kw mat approx 1000x600mm
Flexelec 16a temperature controller (capilliary thermostat)
Rubber pad - slightly larger than the heat mat and approx 1mm thick
Bulkhead style fitting to connect the vacuum hose through the rubber pad
All assembled and working.
Costs:
Equipment
Vac pump - £150 (used)
Heat mat - £125 (unused from ebay)
Temp controller - £25 (new)
Rubber pad - £10
Vac fittings - £20
Mastic tape - £16
Total = £346
Epoxy
5kg High viscosity primer
12kg epoxy
5kg epoxy filler (fairing the hull)
Rollers, brushes, sanding pads etc
Total £520
Labour
Gelpeel - £450
Labour (mine) - 50-60hrs
Total costs to peel, dry and epoxy - £1316
Costs:
Equipment
Rubber pad - £10
Vac fittings - £20
Mastic tape - £16
Total = £346
Epoxy
12kg epoxy
Total £520
Labour
Gelpeel - £450
