LadyInBed
Here's a thought.
Drill a hole, cut a slot across it ø large enough to push a s/s wing nut through it.
Flatten down the tops of the wings (file or grind), screw in from the wing side of the nut a s/s bolt (so wing nut is inverted).
Push it through the slotted hole, rotate the wing nut through 90° , pull the nut tight against the fiberglass and tighten the bolt.
You could put a bit of epoxy on the wings of the nut to hold them captive, also fill the slots if you wanted to go that far.
