Black tyre marks
pandos
15 Oct 2004
Ireland, (Crosshaven)
Anyone with experience of getting these off a white fiberglass hull.
I haven't tried yet but boat is 4 hours drive away and time before saying is limited.
They look pretty bad and have been on there for a few years I suspect...
Regards.
johnalison
14 Feb 2007
Essex
I usually start with basic organic solvents like white spirit or a strong gelcoat cleaner. I find that most marks actually just come off with a wax or wax polish and a good rub.
KevinV
12 Oct 2021
Magic eraser are really abrasive - the scratches are just really small. Better to use a polishing compound imo.
pandos
15 Oct 2004
Yes I had just googled these yokes.
I think wd40 may be a starting point maybe white spirits and acetone, if all comes to all cutting compound or very fine wet and dry..paper..1600ish..
Thanks all...
Concerto
16 Jul 2014
Chatham Maritime Marina
Even if you clean off the tyre rubber marks, I suspect the gel coat will have been abraded with grit on the tyre. You will need to compound the gel coat back to a shine and the use at least 3 coats of a high quality polish that includes UV protection.
pandos
15 Oct 2004
Asking this question before Nanny State took hold, the answer would have been “petrol on a rag”
Don't worry no nanny State where the boat is...that may be the easiest option be cause I can't find the half gallon of acetone. (But it could be at the boat)
It's the outside of the hull so pretty well ventilated.
Thanks to all others for helpful suggestions...
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
Xylene. Acetone is not really a petroleum/rubber solvent; too polar and it dries too fast. Xylene is the main ingredient in most tar removers or other aromatic (xylene is an aromatic solvent--it is a solvent class, not a reference to the smell) solvents. Give it some soak time ... the thicker the layers the more time.
Been there, done that. Not magic eraser either, except perhaps for the last bit.
