BarryH
Some of you know that I've benn building a diesel for the boat. Well I got hold of a Ford Puma lump from a wrecked tranny.....no the van, not a drunk cross dressing man!, pay attention. It had less than a 1000 miles on the clock. All for 500 notes.
So off i go and get all the bits to make it work in the boat. Stripped it down to check ends and stuff, cos a mad parcel delivery driver "cared" for it from new. Had to buy a new cam for it as the case hardening on the exhaust one wass peeling. Bit of a bugger cos they only sell them in sets. Anyhow got one for it and put it all bacvk together. Starts it up and it run fine.
So thinking "ah ha" can get a few more horses out of this I play about with the fueling turbo etc etc. All done on a dyno thats owned by a "mate". Well his company owns it, but the less said 'bout that the better!
After lots of spanner twiddling and an oily hand print on his pristine white workshop wall it was running sweet as a nut, as they say.
Back home in my greasy walled workshop and the kitchen I fittewd all the boat stuff. Heat exchanger manifolds, that sort of stuff.
Took it back to the White walled workshop and bolted it all to the test bench. Started the thing up and let it warm up under mild loading. Temps indicating normal, if 88c is normal, and wind it up to see how it all goes. Idea was to sort of run it in on the bench then stick it in the boat when I get time and get the bellhousing modded to take the lump.
Running nicely at 2000 revs. Next step is to see if its still putting out the indicated 148 horses as before. Open the bugger up, theres an almighty bang and No1 con rod exits the side of the block taking the oil pump with it.
So moral of the story........forget it and stick with the volvo petrol lump. Reason for self destruction. Don't know yet but it looks like the bearing cap broke up.
