Daydream believer
How many through hull fittings actually fail when the boat is in the water & when the owner is not fiddling with them? I had a leak but it was a split hose, not the through hull. I did have to replace a fitting to the heads outlet. However, that was the elbow coming off the seacock, Not the actual valve unit- Which I also replaced but found to be fine.
