Beta Panel A
bluerm166
29 Sep 2009
Does anyone have experience of transferring all the faceplate items on a Beta A panel to a new faceplate ? Assume by inspection that all the items will, with the spades connectors removed and a bezel or ring unscrewed,either come forward or backwards out of the old plate.Particular question : are the star grippers as seen here on the back of the led's a proprietary part of the face plate or a standard and readily available control box accessory ?
Beta A
bluerm166
29 Sep 2009
Yes ,Beta normally helpful but in this case can only sell me a new complete A unit including the extension loom for £225 plus carriage.
i.e. there are no faceplates available.I can make a new faceplate but like to explore the job in hand before committing .
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
Even if you can't get those exact led holders there are plenty of others. The LEDs will be a standard size, Beta don't make those. Measure the led dimensions & have a look on RS. You will lose half a day mesmerized by how many you have to choose from. RS is a dangerous website for those short of time ?
bluerm166
29 Sep 2009
Thanks to all contributors.
Hoped to be able to retain the current lamps because of compatibilty issues but at least I am now looking for 'panel Indicator lamps' should I need replacements and e.g. Railway Scenics or 12 Volt Planet throws up 12v Neon or Incandescents of the same type and connection ,which presumably I could test for voltage range.I suppose that dismantling will reveal all.
(Meanwhile it has been suggested that I just get on with the house and spend the money with Beta .)
Boater Sam
14 Mar 2020
Philippines and Thailand
The ignition charge lamps MUST be incandecent filament bulbs usually 5w rating otherwise your alternator/s may not excite. You can use shunt resistors of 560 ohms 3 watt rating with LEDs and lower wattage incandescent though.
Neons are mains voltage, not 12v.
