alahol2
If you screw the end caps, 'o' rings and the stack together outside the casing you will see how the 'o' ring is supposed to work. It should be squeezed by the chamfers on the end cap and stack which forces it out to also squeeze against the casing. A smear of silicone grease on the 'o' ring assists.
