destroyer28a
Hi i have just bought a boat and have some trouble with the gearbox apparently not selecting gear, but what it actually is seems to be a coupler that goes from the gearbox and the holds the prop shaft, this seems to be spinning about, occasionally it will lock and i can select fwd and get drive, but as soon as i go astern it seems to pop out, and a lot of noises happens and i lose all drive both ahead and astern. Trouble is i dont know what this "spinning" component is called so cant price it up and dont know if the job is doable or do i need a marine specialist to remove the engine?
so my question is what is the bit i need to fix called?
thanks in advance.
thanks in advance.
